2D Drafting
V9, issue with lines (#5124)
I am running V9 on W8. I drew some parts and then group them individually and saved the file. When I reopened the file the groups were still there, but it also created un-grouped lines of the same part. So I have to go through and delete the lines every time I open the file. How do I get it to stop doing this?
I believe this was fixed in the 1109 builds. Can you confirm your build number? 1109 is available via the Current Version menu item under Window. Tim
Originally Posted by: Tim Olson I believe this was fixed in the 1109 builds. Can you confirm your build number? 1109 is available via the Current Version menu item under Window. Tim
I updated the build, that fixed it. Thanks
I do have another problem. This was present before the update and still is an issue. When I export as a DXF or DWG and then reopen the part in VC, the line weight changes to .079. I always draw my parts with a 1px line weight. This does not happen when I just save a VC file and reopen.
2D Drafting
