2 Pages<12
mikeschn
#21 Posted : Thursday, December 24, 2009 11:30:56 AM(UTC)
mikeschn
Steve,
I'll have to try that too!
Mike...
Originally Posted by: Steve.M Go to Quoted Post
Hi Mike.
Ah, right.
At one time I did post movies in divx format, but I dont think some like to have to install another player or the divx codec to play them.
I was having a look at camtasia, but for $300 it is too expensive as I would not use it enough. I will now be using Camstudio(free/open source) and then convert to Mov using quicktime pro ($30) and the result are just as good.
- Steve
Luc, sorry for the off topic.
Steve.M
#22 Posted : Thursday, December 24, 2009 12:21:37 PM(UTC)
Steve.M
Originally Posted by: Luc Go to Quoted Post
The way you draw your bolt inspire me a little idea on how to draw a nut now.
The lead out on the bolt I made is not actually correct, but is ok for quick model. The lead out should be made using an Helix with a draft angle.
I think I will have to inverse the thread to do it.
For a nut, you can actually use a copy of the bolt to boolean out the internal thread.
- Steve
mikeschn
#23 Posted : Thursday, December 24, 2009 3:22:19 PM(UTC)
mikeschn
Steve,
Could you expand on that "helix with a draft angle" comment. I can't picture that at the moment.
Mike...
Steve.M
#24 Posted : Thursday, December 24, 2009 3:47:20 PM(UTC)
Steve.M
Hi Mike,
Of course.
Rather than just using one helix for the thread, you add a second helix with a draft angle for the thread lead out. Then sweep both helix.
Mov attached (this mov is an experiment as I Have changed my screen resolutiuon/ using camstudio for the capture. The mov resolution is also @1024X768. Let me know if any problems viewing..)
Movie direct download
- Steve
mikeschn
#25 Posted : Thursday, December 24, 2009 4:39:48 PM(UTC)
mikeschn
Good job Steve on that movie.
And thanks for explaining the draft. I understand it now.
Mike...
Luc
#26 Posted : Sunday, December 27, 2009 11:25:21 PM(UTC)
Luc
Hi all,
I did the nut threads following Steve advice, using the Subtract Solid tool.
(And Steve, off topics are bonus to me so they are welcomed.)
I am now trying to learn more about my ViaCad. It is fun but not easy for my poor brain. Most of the time I got unexpected results. :-)
What I like most is when I finally understand a new thing and discover new possibilities. Then, I go to bed happy (sometimes too late!)
Luc
Luc attached the following image(s):
Bolt & nuts.jpg (23kb) downloaded 6 time(s).
mikeschn
#27 Posted : Monday, December 28, 2009 7:58:23 AM(UTC)
mikeschn
Hi Luc,
Since you currently like to learn new stuff, here's an easy way to chamfer your nut...
I used a 30 triangle, revolved around the centerline of the nut...
:D
Mike...
mikeschn
#28 Posted : Monday, December 28, 2009 8:03:31 AM(UTC)
mikeschn
BTW Luc,
There are many places where you can get dimensions for standard hardware on the internet if you don't want to buy the machinery handbook.
Here for example...
http://www.portlandbolt.com/products/nuts/
Pick your nut style, and then click on the dimensions tab.
Mike...
mikeschn
#29 Posted : Monday, December 28, 2009 9:33:35 AM(UTC)
mikeschn
Hi Mike.
Ah, right.
- Steve
Steve,
I've created my first movie, and converted it to quicktime's .mov format, same way as you do. But my file is huge... 18 megs for this nut for example. Any suggestions to make it smaller?
http://www.mikenchell.com/images2/nut.mov
Mike...
Steve.M
#30 Posted : Monday, December 28, 2009 3:24:55 PM(UTC)
Steve.M
I have not checked the mov file as my gateway is currently blocking the site:- mikenchell.com. What is that site? I will need to check logs
What you should try:-
For screen capture, cut the color depth to max 8bit per channel(24 bit color depth max). Keep the frame rate to 15 frames or less.
When encoding(converting to mov) drop the quality but have multi-pass encoding.
- Steve
Luc
#31 Posted : Monday, December 28, 2009 4:54:08 PM(UTC)
Luc
Hi all,
With the help of these wonderful movies and great advices of yours I think I made a better draw of my nut.
Not yet the industry standard but better than my first try.
Sometimes I had to post my message twice to see it on the forum. Hope you don't receive it twice.
Luc
Nut 3.jpg (19kb) downloaded 6 time(s).
Steve.M
#32 Posted : Monday, December 28, 2009 5:27:33 PM(UTC)
Steve.M
Hi Luc,
Another way to create the chamfer on the nut:-
Mov direct download
- Steve
mikeschn
#33 Posted : Monday, December 28, 2009 5:47:46 PM(UTC)
mikeschn
Hi Luc,
Mov direct download
- Steve
Steve,
The file size on this movie is nice too! Can you send me the avi file that you created so I can see how you did it? Or tell me which codec you use, and the settings you used...
Mike...
P.S. I don't come across many applications for the use of intersect. The last part I recall doing an intersect on was a diff carrier...
UserPostedImage
Steve.M
#34 Posted : Monday, December 28, 2009 6:12:02 PM(UTC)
Steve.M
Hi Mike,
I am using Camstudio with the "Techsmith capture codec". fps set to 15.(pic01)
Conversion to Mov in quicktime set as shown:-(pic02)
mikeschn
#35 Posted : Monday, December 28, 2009 6:37:42 PM(UTC)
mikeschn
this doesn't look good...
mikeschn
#36 Posted : Tuesday, December 29, 2009 6:02:46 AM(UTC)
mikeschn
Steve,
I reviewed another program, Jing, which is put out by the same people as Camtasia. For $15 one can produce really compact, really high quality mp4 file that you can play in quicktime.
So I tried it. Here's an example...
http://www.mikenchell.com/images2/complete_nut.mp4
and here it is, saved as a movie... (via Quicktime Pro)
http://www.mikenchell.com/images2/complete_nut.mov
It's 3 minutes and 23 seconds long, and it's only 8 megs. :)
Mike...
Steve.M
#37 Posted : Tuesday, December 29, 2009 4:01:08 PM(UTC)
Steve.M
I have looked at that before, but only the free version, and I only got as far as the program insisting I create an account with Screencast.com to continue, so I removed the program.
Does the paid-for program make you create an account with screencast.com for it to work? I also dont really like the fact that it only captures 5 minutes.
- Steve
mikeschn
#38 Posted : Tuesday, December 29, 2009 4:45:31 PM(UTC)
mikeschn
- Steve
Yes, it forces you to create an account. But you don't have to use that account. I save my files to my desktop, and then host them on my own server.
Yes, I was a little concerned about the 5 minute limit, but then I decided that I would probably only do short movies anyways.
For the high quality, and the small file size, it was worth spending $14.95. :rolleyes:
Mike...
P.S. Can't you combine movies in Quicktime Pro?
edit... yep!!!
Combining Two QuickTime Movies into One
With QuickTime Pro, you can easily add one movie to another to make one longer movie.
To combine two movies:
1. In QuickTime Player, choose Edit > Select All to select the entire contents of the first movie.
2. Choose Edit > Copy, then open the second movie.
3. Move the playhead to the point at which you want to insert the movie (usually the very beginning or end of the original movie), and choose Edit > Paste.
4. Choose File > Save As to name and save the new movie.
Steve.M
#39 Posted : Tuesday, December 29, 2009 5:20:34 PM(UTC)
Steve.M
I am not really concerned with the small cost, just with the program wanting to connect out (which is probably every time you run it). Call me paranoid, but I am very security conscious and control all internet connections for my own use, I do not allow programs to connect out whenever they want to
I can workaround, using the camstudio lossless capture-> expand to RGB, convert to MOV. I will use that or go back to xvid, or stop making movies.
Jean-Francois Jacques
#40 Posted : Thursday, September 18, 2014 1:32:39 PM(UTC)
Canada
ACIS SAT is also a good format. Yes, I use McMaster for a long time. Is very useful.
METEORE DESIGN / KEKO Stand
SharkCad Pro V14 B1653
Platform macOS 14 Sonoma
Guest (10)
2 Pages<12
