Originally Posted by: Steve.M
I have looked at that before, but only the free version, and I only got as far as the program insisting I create an account with Screencast.com to continue, so I removed the program.
Does the paid-for program make you create an account with screencast.com for it to work? I also dont really like the fact that it only captures 5 minutes.
- Steve
Yes, it forces you to create an account. But you don't have to use that account. I save my files to my desktop, and then host them on my own server.
Yes, I was a little concerned about the 5 minute limit, but then I decided that I would probably only do short movies anyways.
For the high quality, and the small file size, it was worth spending $14.95. :rolleyes:
Mike...
P.S. Can't you combine movies in Quicktime Pro?
edit... yep!!!
Combining Two QuickTime Movies into One
With QuickTime Pro, you can easily add one movie to another to make one longer movie.
To combine two movies:
1. In QuickTime Player, choose Edit > Select All to select the entire contents of the first movie.
2. Choose Edit > Copy, then open the second movie.
3. Move the playhead to the point at which you want to insert the movie (usually the very beginning or end of the original movie), and choose Edit > Paste.
4. Choose File > Save As to name and save the new movie.
