Spleeve
#1 Posted : Tuesday, June 26, 2007 4:44:09 AM(UTC)
Spleeve
1. Does ViaCad have a nudge feature for translating objects?
2. Is there any keyboard shortcut to constrain translations, extrusions etc. to a specific plane. I keep finding that even when in front, side or top view that my extrusions are 'off' and I have to correct numerically - another step I would rather not do if there is a better way to constrain by dragging.
Thanks, Mike.
Todd Quinlan
#2 Posted : Tuesday, June 26, 2007 7:29:08 AM(UTC)
Todd Quinlan
ViaCAD does have a nudge feature to move objects around with the keyboard arrow keys.
To set this up you will need to go into File/preferences and under the general tab you will see a value box next to the words "arrow key nudge distance". If this value is set to 0.0 the arrow keys will nudge the whole screen. If however you set this to any other value, a selected object will be nudged that distance in your set units.
To constrain to a certain axis/plane when moving your mouse to translate or extrude hold down the letter representing the desired axis. In other words if you want to stick to the y axis hold down the y when moving. This constrain works with any tool and with any function.
Todd Q
CAD Support Specialist
Encore Software/ IMSI Design
Reuben5150
#3 Posted : Tuesday, June 26, 2007 4:18:12 PM(UTC)
Reuben5150
Great !, i'm sure i tried that and didn't work though :confused:
Reuben
joev
#4 Posted : Tuesday, June 26, 2007 8:27:42 PM(UTC)
joev
Reuben
It can be a bit inconsistent. I try to have the constraint key pressed before I click on an element. One other thing to be aware of, the Z axis is up in the perspective view and in planar views, Y is up.
