#1 Posted : Friday, January 7, 2011 2:48:32 PM(UTC)
I don know if it is a bug
The bottom view on the display interface it is 180 rotated, this is confuse for me in some edit procedures.
This should be displayed as the same way as the bottom view on viewports on the sheetlayer drawings on the model to sheet commands.
please look a the pictures
[ATTACH]3662[/ATTACH]
[ATTACH]3664[/ATTACH]
MacOSX 10.10, Yosemite
Shark FX V8, Beta testing Shark FX V9-1146
mikeschn
#2 Posted : Friday, January 7, 2011 6:44:49 PM(UTC)
mikeschn
I just did a quick drawing, and it's exactly as I expected.
Of course I am drawing in 3rd angle projection. Also the system canned views are also set up in 3rd angle projection. If you are drawing in first angle projection, might that explain the difference?
Mike...
mikeschn
#3 Posted : Friday, January 7, 2011 7:01:04 PM(UTC)
mikeschn
Even in first angle projection it appears okay.
Can you attach your file?
Mike...
#4 Posted : Friday, January 7, 2011 8:36:01 PM(UTC)
Mike...
yes, when you do the projection in viewport then they are displayed good, so there is no problem there
the problem is when you are working on the model, if you rotate the view (menu/view/bottom), then the model displayed from the bottom but rotated 180, the front of the model should be facing the up side of the screen, and what happen it is that is looking through the bottom of it
Sorry about my english, maybe i can not explain this clearly.
here you have a sample file, the viewports display the views the right way, try this, activate the layer1, hide the sheetlayer 1, now you should have a top view of the model, form main menu select view/bottom, you should end with the same view as the one of the bottom viewport on the sheet layer, but the resulted view it is rotated, backward.
Luis G.
samplebkt.sfx (210kb) downloaded 5 time(s).
mikeschn
#5 Posted : Saturday, January 8, 2011 5:06:41 AM(UTC)
mikeschn
Luis,
Thanks for attaching your file. You are right. The system defined bottom view is off by 180.
I confirmed that on one of my own files...
Tim, can you fix the system defined bottom view?
Mike...
#6 Posted : Monday, January 10, 2011 6:53:01 PM(UTC)
yes Tim please, is kinda confusing to edit a part when you are in bottom view (many times i move the things in inverted direction)
Luis G.
Guest (5)
