Originally Posted by: mikeschn ![Go to Quoted Post Go to Quoted Post](/Themes/punchcad2/icon_latest_reply.gif)
Even in first angle projection it appears okay.
Can you attach your file?
Mike...
yes, when you do the projection in viewport then they are displayed good, so there is no problem there
the problem is when you are working on the model, if you rotate the view (menu/view/bottom), then the model displayed from the bottom but rotated 180, the front of the model should be facing the up side of the screen, and what happen it is that is looking through the bottom of it
Sorry about my english, maybe i can not explain this clearly.
here you have a sample file, the viewports display the views the right way, try this, activate the layer1, hide the sheetlayer 1, now you should have a top view of the model, form main menu select view/bottom, you should end with the same view as the one of the bottom viewport on the sheet layer, but the resulted view it is rotated, backward.
Luis G.
![](/Themes/punchcad2/icon_file.gif)
samplebkt.sfx
(210kb) downloaded 5 time(s).You cannot view/download attachments. Try to login or register.
