KrisM
#1 Posted : Tuesday, October 29, 2013 3:34:18 PM(UTC)
KrisM
I have some parts imported from SketchUp. I have stitched them to become stitched solids. They are at an angle from horizontal and so the BOM attributes are not the actual size of the object but rather the volume of the object measured by the normal xyz axes. Is there a way to adjust the xyz axes of the object to follow the angle of the object and so get an accurate BOM?
Kris
#2 Posted : Tuesday, October 29, 2013 3:49:06 PM(UTC)
Hi Kris,
Shark FX can assign an axis to an object but it is not used when making a BOM.
Which BOM are using that is axis dependent?
KrisM
#3 Posted : Tuesday, October 29, 2013 3:53:33 PM(UTC)
KrisM
Tim,
I'm using the Attributes/BOM window in Via Cad. I export the BOM to get a timber list in Excel. I can correct the axes in SketchUp but was wondering if I can do the same in ViaCad.
Kris
KrisM
#4 Posted : Tuesday, October 29, 2013 3:55:32 PM(UTC)
KrisM
I should have added - I'm using the "Extent Properties".
Kris
KrisM
#5 Posted : Tuesday, October 29, 2013 3:59:34 PM(UTC)
KrisM
An additional addition - The axes in SketchUp are correctly aligned along the object so Via Cad is seems to be defining the extents of the object with respect to the normal xyz orientation rather than the Sketchup orientation.
Kris
