kevjon
#1 Posted : Saturday, June 14, 2014 2:19:04 AM(UTC)
kevjon
When I follow this exercise from the manual in ViaCAD 9
I get the error gaps detected in surface ? Fix Gap and try again.
kevjon attached the following image(s):
rockyroad_us
#2 Posted : Saturday, June 14, 2014 3:00:54 PM(UTC)
rockyroad_us
Post a file to review.
kevjon
#3 Posted : Saturday, June 14, 2014 3:47:56 PM(UTC)
kevjon
Here you go.
Cover Surface with Guides.vcp (10kb) downloaded 27 time(s).
rockyroad_us
#4 Posted : Saturday, June 14, 2014 4:35:53 PM(UTC)
rockyroad_us
I don't get the error. I think if you ellipse was made with curves and not closed, it will give an error. here's a video I made.
coversurface.mov (729kb) downloaded 71 time(s).
kevjon
#5 Posted : Saturday, June 14, 2014 4:49:05 PM(UTC)
kevjon
I see what the problem is now.
ViaCAD Pro 9 doesn't have the tool you show in your movie.
It only has cover surface.
thanks 1 user thanked kevjon for this useful post.
ArtRedGreen on 3/3/2015(UTC)
ArtRedGreen
#6 Posted : Tuesday, March 3, 2015 10:30:18 AM(UTC)
ArtRedGreen
Originally Posted by: kevjon Go to Quoted Post
I see what the problem is now. ViaCAD Pro 9 doesn't have the tool you show in your movie. It only has cover surface.
FYI: I have the same button missing (ViacdPro V9, Build 1109 on Mac)
ArtRedGreen
#7 Posted : Tuesday, March 3, 2015 11:04:02 AM(UTC)
ArtRedGreen
Found a Solution/WorkAround:
Pick from the Menu: Modify>> solid direct edit >> Deform Face
other solutions are welcome...
Paul Copping
#8 Posted : Sunday, June 14, 2015 1:19:16 AM(UTC)
Paul Copping
Hi, I know this is no help but I have same problem too. There is no option for Cover Surface with Guide in ViaCAD V9 Pro but it is in the Manual and I have seen in Punch CAD Video on You Tube.
When will this be corrected, Tim?
Paul
