Originally Posted by: jdi000
Hi jtfx
There is a bug here it seems where the holes located on the xz & yz plane are not displaying the center dim mark, I am getting half the mark but not the vertical part. If your holes were on the xy plane they would display. This is only happening on polyline edges.
The option click during hole creation is to create a center point when the hole is created.
ViaCAD & ViaCAD Pro draws a polyline approximation instead of precise curves in the sheet views but it will accurately dimension a radius or diameter dimension the program pulls the precise dimension corresponding to the polyline representation of each curve, and the center dim mark should definitely work when everything is running good.
I took a look at your file and see what you mean.
However, I must be doing something else wrong as I can't get my center dimension to work in any plane? I can't get the horizontal center line in the xz, yz planes as your file shows, or both in the xy plane.
The file you attached, you just created a block, used the simple hole tool and created the holes, went to sheet view, picked the center dimension tool, clicked on the edge of the circle and it worked, or half worked, depending on what plane your hole was in?
That is what I tried, and I'm merrily clicking away with the center dimension tool in sheet view and nothing happens...
Edit: Sorry newbie mistake, I didn't realize I needed to select the particular view in sheet view before trying to add the center dimension to a hole on that face.
