Import/Export
Importing a dwg file (#4689)
I recently imported a dwg file. It opens alright but when I try and select one object everything gets selected and stays selected no matter what I do. There are different sections to it they are in MTS but everything is in one layer I would like break it down to different layers to simplify the drawing. Any ideas? Thanks Jim
Does ungroup do anything?
either a group or a symbol, check titlebar of the "Window > Inspector" for the entity type. as already mentioned, ungrouping should resolve the issue. Norbert
They are not grouped. Norbert i am not sure what you mean by entity type in inspector. Jim
Originally Posted by: jimb ...what you mean by entity type in inspector.
the entity type of the selected element(s) is displayed in the [URL="http://en.wikipedia.org/wiki/Title_bar"]title bar[/URL] of the Inspector window, at least if only one element selected or multiple elements of the same type.
hth,
Norbert
Norbert What are you running ? I am using Shart Lt. I don't see what you are talking about. But maybe i am having a blonde day Jim
In the title bar it say default settings Jim
OSX?
I'm running everything :rolleyes:
in the title bar of the Inspector window (see attach).
hth,
Norbert
posh.de attached the following image(s):
(94kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
The imported drawing says default settings. If I draw a line inspector say line. I wonder if the sender sent it as a read only file. Jim
Have you looked at the file with a 2D-CAD Program ? [For my hobby interests i am using [URL="http://librecad.org/cms/home.html"]LibreCAD[/URL] for inspecting/repairing DXF/DWG-Files] Roland
Originally Posted by: jimb The imported drawing says default settings. If I draw a line inspector say line.
"default settings" is shown if nothing is selected.
do a "zoom all" and try to select again.
for evaluation purposes you may also try the free [URL="http://www.opendesign.com/guestfiles/teigha_viewer"]ODA Teigha Viewer[/URL] f. Win/OSX.
hth,
Norbert
Import/Export
