short cut key for select (#4569)
Is there a way of having a short cut for select in Shark Lt
i don't know about LT but i do know fx does and it is handy.
there is no key assigned to that command. You need to assign it a key through short cuts. Assign it a key.
Thanks i found it. It is under a select tools. In version 6 its under edit.
I wish the space bar could be decoupled from the Pan tool. I have to assign it to the Select tool every single time I start the program. Maybe for Christmas?! : )
Thanks: 140 times Was thanked: 124 time(s) in 84 post(s)
I use the ~ backtick/tilde key for select. I do not often use the spacebar for panning, but it is handy at times. ..... Well, just now, i reassigned the spacebar to the Gripper, since i realized inalsonhad my zero key also set for dynamic panning. But, this is in VCP 7 967.
I use the s key for select i didn't realize you could assign the spacebar as a short cut.
It appears the spacebar assignment is not "sticky". It does not persist across sessions. :-( Comma now is my gripper shortcut...
