Thanks: 103 times Was thanked: 18 time(s) in 14 post(s)
Using SharkCad 10 here – I cannot find the Edge or Vertex select for subdivision modification. I thought these selection-tools existed but I could be wrong. I am able to use Deep Select to select faces. But doesn't allow me to select edges or vertex points. Is this a powerpack tool? Thank you
In VCP 10 Pro I can select edges with the gripper.
To catch an edge it needs to pull a smaler frame than in the Preferences - Snaps - Settings is definited.
horst.w
GER
Edited by user Saturday, February 23, 2019 2:03:04 PM(UTC)
(24kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
1 user thanked horst.w for this useful post.
PowerPack ---> Feauture Selections
1 user thanked digitalphaser for this useful post.
Shark Pro 1365 using the selection tool, stretch window around the vertex/es that mark the point or edge, not PP.
Edited by user Sunday, February 24, 2019 11:06:35 PM(UTC)
In addition to the PowerPack : Feature Selections you can right click on a mesh to have a couple of extra selection options such as Select Edge Chain.
(622kb) downloaded 13 time(s). You cannot view/download attachments. Try to login or register.
