The Mirror Feature destroy the real name of a part
Thanks: 351 times Was thanked: 257 time(s) in 169 post(s)
This cause huge errors with the mass properties and the BOM because the BOM will not have the right material for this part.
Edit: The same problem with the Translate-Feature and the Rotate-Feature and the Scale-Feature.
Edited by user Wednesday, February 6, 2019 8:00:31 AM(UTC)
(18kb) downloaded 29 time(s). You cannot view/download attachments. Try to login or register.
Workaround: Delete always the history or select all and remove links (works with a selfmade shortcut) before you create a Cutlist-Information. And never do new features to the item, then will your Cutlist-Information be broken. And beware in shark 9 - cleaning History will delete the Cutlist-Information always, not only when new features like holes and translations added.
If you want mirroring or translating a part which already in cutlist, remove links before using the Mirror and translate tools because otherwise your part-name and Material (Cutlist-Information) will be broken. Shark 9 never clean the history when a cutlist created, just remove links.
Edited by user Thursday, July 23, 2020 1:18:11 PM(UTC)
2 users thanked MPSchmied for this useful post.
