crazyhardware
#1 Posted : Thursday, January 10, 2019 10:31:20 AM(UTC)
crazyhardware
I use ViaCAD pro V11 Build 1422 with the Powerpack V11.
The Function PowerPack -> Draw -> Shadow Projection do not work.
If you pick a solid for projection the outlines get red, but nothing happend.
Hansi
Windows 10 64-Bit, ViaCAD Pro V9 & V10 & V11 Build 1422, PowerPack V11
#2 Posted : Thursday, January 10, 2019 3:59:19 PM(UTC)
Was thanked: 75 time(s) in 62 post(s)
Confirmed on my V11 in windows 7 pro. Each option does nothing.
Shark CAD + Power Pack Pro
L. Banasky
#3 Posted : Friday, January 11, 2019 3:19:30 PM(UTC)
L. Banasky
Was thanked: 72 time(s) in 60 post(s)
Tried in SharkCad Pro 10, seems to work.
Try moving the solid after the Shadow Projection,
it just might be there.
Shadow Projection.jpg (13kb) downloaded 1 time(s).
#4 Posted : Friday, January 11, 2019 4:04:33 PM(UTC)
Nope still nothing. I just tried in Shark 10 (non pro) and it works. Although, when you do the shadow, and then move the object the shadow doesn't update, however it is linked, as you can go and remove the links in the menu?
L. Banasky
#5 Posted : Saturday, January 12, 2019 1:10:09 PM(UTC)
L. Banasky
Selecting the correct Planes?
Select Plane.jpg (95kb) downloaded 12 time(s).
XY Plane with 'Ctrl'.jpg (178kb) downloaded 7 time(s).
#6 Posted : Sunday, January 13, 2019 3:25:11 AM(UTC)
Yep every option does nothing. Have you tried moving that solid shape and see if the shadow follows? Like I say it's a linked surface put the link seems to be pointless if it doesn't move with the solid?
L. Banasky
#7 Posted : Sunday, January 13, 2019 12:47:36 PM(UTC)
L. Banasky
For me , the only value of this feature, is 'Ctrl' Outline of
a solid, and Export as a .dxf for plasma cutting.
Is there another use for this feature? Doesn't seem to do
much .
