Koen
#1 Posted : Wednesday, October 10, 2018 3:56:37 PM(UTC)
Koen
Isometric view-partialHello,
I'm running Viacad Pro 10, build 1359; on Windows 10.
I'm encountering a serious issue when displaying an object in isometric perspective.
See below screenshot.
The problem gradually disappears when changing the perspective by mouse.
I played around with view properties/focal length, but that does not change anything. Oddly enough, when flipping the view 180 degrees, the object will display completely.
I searched online and in the program in each setting possible, but I cannot find a solution.
Am I missing something and is it a matter of changing a setting or is it a bug?
Many thanks in advance,
Koen
Koen attached the following image(s):
Viacad10 - isometric.jpg (390kb) downloaded 10 time(s).
#2 Posted : Wednesday, October 10, 2018 6:21:50 PM(UTC)
Was thanked: 78 time(s) in 75 post(s)
Koen
Koen
Is specific to this file? Try exporting as a ViaCAD file and opening the exported file.
Windows 10, Win 7
Koen
#3 Posted : Tuesday, October 16, 2018 3:15:21 PM(UTC)
Koen
Hi Jason,
Sorry it took a bit longer to get back to you.
I found the issue, but I do not know how to solve it.
Basically: in isometric view, everything that is positioned in the test drawing below Y= -230 cm (under the red line) doesn't get displayed. No issues in top view.
I also attached the file so you can have a look.
Edited by user Tuesday, October 16, 2018 3:17:25 PM(UTC)  | Reason: Not specified
Drawing issue.vcp (7kb) downloaded 4 time(s).
Viacad10 - isometric problem.jpg (346kb) downloaded 2 time(s).
L. Banasky
#4 Posted : Tuesday, October 16, 2018 3:33:37 PM(UTC)
L. Banasky
Was thanked: 87 time(s) in 70 post(s)
Seems to open o.k. on Shark PC
Isometric on PC.jpg (47kb) downloaded 1 time(s).
Koen
#5 Posted : Wednesday, October 17, 2018 3:18:22 PM(UTC)
Koen
I experimented a bit more, it is definitely an issue in the isometric (and trimetric) view for all lines/points that are under Y=-300.
Viacad10 - isometric problem 2.jpg (1,207kb) downloaded 4 time(s).
isometric view issue.vcp (26kb) downloaded 3 time(s).
rockyroad_us
#6 Posted : Wednesday, October 17, 2018 4:06:57 PM(UTC)
rockyroad_us
Was thanked: 26 time(s) in 25 post(s)
Same here. I opened the Drawing issue file and it opened okay. It might be related to your graphics card. Once a year, I clean my system internally to avoid low performance. The card collects dust like hell and I break down my machine and vacuum and pressure blow the fans. You won't believe how much dust it can collect within a few months. Also, it can be a fire hazard.
FX 7-10 Pro12-1559
OSX.13.6
2x2.8GHz Quad Xeon
32GB
Radeon HD6870 2GB
Koen
#7 Posted : Thursday, October 18, 2018 2:29:10 PM(UTC)
Koen
Thanks for the advice ... I'm running this on a laptop :-)
Speaking of which... I tried running the program on the integrated graphic core (Intel 620) and on the additional graphic "card": Nvidia Geforce MX150. No difference.
Did you open the drawing in Viacad or in Shark?
rockyroad_us
#8 Posted : Thursday, October 18, 2018 4:29:12 PM(UTC)
rockyroad_us
I opened them in both and both are okay. I've noticed you are in 1359. I believe there's a build 1371 that you should upgrade to. Maybe that will fix your issue.
FX 7-10 Pro12-1559
OSX.13.6
2x2.8GHz Quad Xeon
32GB
Radeon HD6870 2GB
