Hi all!
I'm using ViCAD10Pro (v10.0.6_1369) + PowerPack on Windows10Pro64.
The issue I faced is that I had to modify model created a month ago (and it's drawing sheet was issued too), but now, after the model modification, all the drawing views show pictures of unmodified or partially modified model.
When I press "Regen Draw View" of the "Model To Sheet" drawing tool then it prompts me that "4 views need to be regenerated", well, I press Okay and ... nothing happens except changing of "Regen Manually" property (becomes checked) of all the pseudo-updated drawing views. If I press "Regen Draw View" again it prompts me that "all draw views are up to date" what sounds as "don't believe your eyes". Screenshot attached.
At the same time, if I use "Model To Sheet" again, then a new sheet appears with views of current model revision.
Of course I can place all the dimensions and text again since no time to wait for fix, but please let me know ASAP if there is a workaround or what I do wrong way.
Looking forward for any help.
Andrey
Edited by user Thursday, June 28, 2018 5:51:55 AM(UTC)
Sviyaz attached the following image(s):
(203kb) downloaded 7 time(s).You cannot view/download attachments. Try to login or register.
