Suggestions
Selection Tool should be always available with a stroke-command.
Thanks: 36 times Was thanked: 12 time(s) in 11 post(s)
The jumping between the selection tool and a tool is just a pain. Please give us a stroke command, that we can take the selection tool always during working with any tool or while drawing a line. It should work in the same way like the zoom and rotate and pan view stroke commands. The operation with the tool should not abort while using this command like Ctrl+Shift and zoom frame or alt and right mouse button or Space and Left Mouse.
Any operation that requires a selection can be done with the tool itself. With the flexibility of the program, there are many ways to work though, could you give an example of your need to use the selection tool while in another tool? This way I can formulate a proper feature request for the development staff.
Todd Q CAD Support Specialist Encore Software/ IMSI Design
Yes, you right, while drawing a line is this not needed. But when you have for example the Dimension tool in hand and wanna make alot Dimensions on several draw views, you must take the selectiion tool to activate a draw view and then you have to take the dimension tool again. This was the reason why i made this suggestion. Sure, Translating some Lines with the selectiion tool while drawing another line will be a little bit senseless, but i guess there are also other reasons why this will be useful. Sometimes while working i wish a Hotkey for jumping betweenthe last 2used tools. The most time are this Tools between i jumping only the selection tool and another tool. Keeping the active operation is maybe not needed for jumping to the selection tool and back to the mainly used tool.
Thanks: 1 times Was thanked: 72 time(s) in 70 post(s)
MP
I assign a shortcut key to the selection command so I don't have to keep going to the menu.
(14kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
Windows 10, Win 7
Originally Posted by: jdi000 MP I assign a shortcut key to the selection command so I don't have to keep going to the menu. Regards Jason
This is not the solution and this made i already, i used the N-key.
You can't jump back easy to your main used tool (for example the dimension-tool)
If the shortcut is made for
Edit -> Deselect All instead of the
select tool you will already be in your main tool.
Two clicks are needed with this method though.
Edited by user Sunday, April 29, 2018 3:24:47 AM(UTC)
Bill Bedford Viacad Pro 11 (11417) OS X 10.13.6
Originally Posted by: BillB If the shortcut is made for Edit -> Deselect All instead of the select tool you will already be in your main tool. Two clicks are needed with this method though.
How to activate a draw view with the "Deselect all" - Command? Works it in a different way when used via a keyboard shortcut?
Originally Posted by: jdi000 shortcut key to the selection command
Hello Jason, Your image shows how to make a short cut key with the digit 1. This is useless because entering values while drawing works then no longer properly. Also are the + and - key using for zoom in the same way useless.
regards
Matthias Pester
Edited by user Tuesday, May 01, 2018 9:44:45 AM(UTC)
Suggestions
