theo52
#1 Posted : Friday, March 30, 2018 1:11:01 AM(UTC)
theo52
Netherlands
I do have some printing issues but only in combination with a solid model.
If i select the dimension layer, only the dimensions are printed.
By selecting another layer the solid model is printed.
If I replace the a solid draw to the dimension layer only the solid model is printable?
In my page layout all looks good, the solid model with its dimensions..
Does anyone has an idea how to solve this?
Kind regard, Theo
#2 Posted : Friday, March 30, 2018 1:05:35 PM(UTC)
Was thanked: 75 time(s) in 73 post(s)
Hello Theo
Are you using a draw view or are you just printing the 3d model? What do you mean by select the dimension layer. Are you toggling the layer print button in the layers tab?
If the field is blank no icon then it will print. If the field has the printer icon it will ignore that layer.
Windows 10, Win 7
