NeuTechFLA
#1 Posted : Friday, January 05, 2018 3:51:47 PM(UTC)
NeuTechFLA
I am not sure this will be of value to anyone, but I thought I would share the outcome. This Topic is a follow up to a previous thread of early this morning (Jan 5 2018). This is a method to get a linear draft angle result on a revolved part. I will post picture of the incorrect method/result in a separate post.
Edited by user Friday, January 05, 2018 3:58:51 PM(UTC)  | Reason: Not specified
NeuTechFLA
#2 Posted : Friday, January 05, 2018 4:00:27 PM(UTC)
NeuTechFLA
Incorrect
drag at 1.jpg (301kb) downloaded 13 time(s).
NeuTechFLA
#3 Posted : Friday, January 05, 2018 6:27:21 PM(UTC)
NeuTechFLA
Upon further consideration, I think this part can be created with two sections instead of the four I show in the example. I will try that over the weekend.
Update.....
Yes, it is possible with two sections. Although I am sure you all knew that already. I am a Shark Noob and am simply sharing what I am learning.
Edited by user Saturday, January 06, 2018 6:31:26 AM(UTC)  | Reason: Not specified
two sections.jpg (329kb) downloaded 8 time(s).
two section result.jpg (340kb) downloaded 8 time(s).
