#1 Posted : Tuesday, January 2, 2018 3:35:47 AM(UTC)
Just looking for some confirmation on the changes on coord compare tool. We now get some extra figures which is great, but I don't understand what they are?
Basically just opened up a model, stuck a single mesh on a face of the tool, and did a coord compare. Tells me it's sat on the face, great stuff, but then tells me the deviation in x, y and z locations is miles off? There's no lines put in the model to tell me what these errors are, what are they?
Cheers
Edit *****Figured it out. Is this deviation or simply just the extremities of the piece you checking? It's not the deviation against the piece you're checking too?
Edited by user Tuesday, January 2, 2018 3:40:30 AM(UTC)  | Reason: Not specified
DEV1.txt (1kb) downloaded 1 time(s).
Untitled 1.jpg (47kb) downloaded 2 time(s).
