NeuTechFLA
#1 Posted : Tuesday, December 19, 2017 8:15:22 AM(UTC)
NeuTechFLA
I cannot seem to get a part (a cylinder with draft) to "insert" itself axially to another part when using the tool in mates. I am a noob at SharkCad so please go easy on me.
Thanks in advance
Edited by user Tuesday, December 19, 2017 8:16:01 AM(UTC)  | Reason: Not specified
#2 Posted : Tuesday, December 19, 2017 8:34:58 AM(UTC)
Was thanked: 303 time(s) in 205 post(s)
Hi, I would go Connection - and align the centre points. Then go Align Face, and then that can move the cylinder into the hole (or whatever) and this can be adjusted with an offset.
NeuTechFLA on 12/19/2017(UTC)
#3 Posted : Tuesday, December 19, 2017 8:47:48 AM(UTC)
Hello
If you are using the insert face tool you need to do 4 selections
1 select the face of the pins outer diameter
2 select the face of the inside of the hole
3 select the bottom face of the pin
4 select the planer surface of the object that the hole is in
