macnavi
#1 Posted : Wednesday, September 13, 2017 4:03:57 AM(UTC)
macnavi
Netherlands
Issue: When copying solids from a document which is viewed in wireframe, the moment you paste the solids in a document with the viewing set as 'Display with shading', it will change the viewing setting to 'Display in Wireframe'.
Step to replicate:
1. Have two documents open
2. Having viewing in one document with shading, the other in wireframe
3. Copy solids from wireframe document
4. Past solids in shading document
Result:
5. Document changes to wireframe.
However, after you've changed the setting back to shading, when you undo the paste and then paste again, it doesn't change the viewing again.
Just noticed and thought I bring it to your attention.
Mac OS X El Capitan 10.12.5 - VC 2D/3D v10
