#1 Posted : Tuesday, May 16, 2017 8:36:21 AM(UTC)
Was thanked: 7 time(s) in 6 post(s)
At Time the "Parallel Dimension" works only in the working plane. Alsw when snapping a point outside of the working plane it seems it get this point, but if turning the Solid, you can see that the parallel dimension snapped not to the selected point and this end is in the free space on the working plane. This is not a good idea. I have to make first a 3 point working plane to be able to create a 3D Dimension. The digits should be readable on screen ond not on working plane.
