New Topic Post Reply
creativecad
#1 Posted : Tuesday, April 18, 2017 8:15:00 PM(UTC)
Quote
creativecad
Here is a dilemma. I don't know if there is a way around this or not. Using the shark pro beta, I rotated the bottom view 180 degrees to get a mirrored view of the handrail. When I started dimensioning in the view, the dimension text was also upside down. I would think the dimensions should always stay right side up or there should be a way to rotate the text.
SharkCAD Pro _Cable rail.pdf (19kb) downloaded 6 time(s).
creativecad attached the following image(s):
#2 Posted : Wednesday, April 19, 2017 10:29:39 AM(UTC)
Quote
Was thanked: 162 time(s) in 142 post(s)
Dimension text direction is determined by the workplane x-axis y-axis.
ViaCAD/Shark Development Team
EvoSoft
Links to ViaCAD Resources
creativecad
#3 Posted : Wednesday, April 19, 2017 8:24:46 PM(UTC)
Quote
creativecad
Ok, I'll see what my workplane is doing. Thanks.
creativecad
#4 Posted : Sunday, April 23, 2017 1:22:20 PM(UTC)
Quote
creativecad
I messed with the work plane, and it did not work very smoothly until I flipped the workplanes around differently before using the model to sheet, and the dimensions finally showed correctly. After playing with this, I do think that if you for some odd reason wanted to show a particular object upside down that you would run into trouble getting the workplanes to work so that the dimensions would be right side up. I am not sure that anyone would ever really need this though.
Quick Reply Show Quick Reply
You can post new topics in this forum.
You can reply to topics in this forum.
You can delete your posts in this forum.
You can edit your posts in this forum.
You can vote in polls in this forum.
