tomg
#1 Posted : Wednesday, March 01, 2017 9:33:18 AM(UTC)
tomg
One of the most difficult concepts in transitioning to 3d CAD is using planes. I am an advanced 2D person and I'm having difficulty with attaching and manipulating working planes. I can't find a tutorial on the subject. Does anyone know of one?
As an example: I easily drew a curved 2d profile of a foot for some equipment, extruded the profile and shelled it. Worked great. I now need to set a working plane on the feet of this form and tilt it 5 degrees. I can't seem to figure out how to set that plane and tilt it. I sure could use a tutorial on planes. I've talked to others that have tried to move to 3D and this seems to be the biggest barrier (learning curve) issue they have too.
#2 Posted : Friday, March 03, 2017 3:10:42 PM(UTC)
Was thanked: 189 time(s) in 167 post(s)
The WorkPlane menu has tools to set the orientation from picking three points or referencing objects. In the video below I use the WorkPlane : Select Object and construct some geometry on a tilted part face.
https://youtu.be/sSt6QvVgDW8
Edited by user Friday, March 03, 2017 3:26:18 PM(UTC)  | Reason: Not specified
ViaCAD/Shark Development Team
Links to ViaCAD Resources
thanks 2 users thanked Tim Olson for this useful post.
Andrew Gray on 3/3/2017(UTC), digitalphaser on 3/4/2017(UTC)
digitalphaser
#3 Posted : Saturday, March 04, 2017 1:51:55 PM(UTC)
digitalphaser
Was thanked: 14 time(s) in 14 post(s)
Thank you Tim for the excellent video. I do not even know about this feature. Very helpful.
horst.w
#4 Posted : Saturday, March 04, 2017 2:04:52 PM(UTC)
horst.w
Was thanked: 13 time(s) in 11 post(s)
@ Tim Olson
I reconstructed your advices by the video to create 3D-textes on a changed work plane as shown.
I was succeful to do it on the origine work plane of a new sheet, but not after arange the work plane to a surface of a model (3-points). The result is very strange.
I have attached a picture of the screen and the vcp-file.
Best regards
horst.w, GER
Edited by user Saturday, March 04, 2017 2:11:35 PM(UTC)  | Reason: Not specified
Workplane-Text-3D.vcp (96kb) downloaded 8 time(s).
Test Namen.jpg (40kb) downloaded 5 time(s).
ViaCAD 9 Pro german + ViaCAD 10 Pro & PowerPack
horst.w
#5 Posted : Saturday, March 04, 2017 2:27:06 PM(UTC)
horst.w
here an other picture with the same origine work plane level as TEST Namen.
I wrote the text "TEST neu" and turned it around 2 axis so that it is laying diagonally and tilded to the work plane.
Then I extruded it as solid with the tool but only the inside-bloc of the "e" of the 2nd-last character was coming up instead of it becomes hollow.
H.
Edited by user Saturday, March 04, 2017 2:30:02 PM(UTC)  | Reason: Not specified
Test turned 2time.jpg (60kb) downloaded 5 time(s).
#6 Posted : Monday, March 06, 2017 4:28:10 PM(UTC)
I tried your model with the latest SharkCAD beta and the text extruded correctly. What build of ViaCAD are you using?
horst.w
#7 Posted : Tuesday, March 07, 2017 6:27:23 AM(UTC)
horst.w
I use the latest (?) version of V 10 Pro 10.0.0 Build 1318
parallel installed V 9 german but not in use at the moment.
H.
PS Win 7 pro 64 bit, laptop Intel ??? 8 GB ram
Edited by user Tuesday, March 07, 2017 6:30:46 AM(UTC)  | Reason: Not specified
horst.w
#8 Posted : Wednesday, March 08, 2017 5:46:52 AM(UTC)
horst.w
Hi Tim
I have an other phenomenon found out.
What I have done?
- Create a Cube
- Given to this cube a Constant Chamfer
- Change the Workplane to this chamfer by using 3-Pts option.
Result for textes:
In a first tray the text "TEST" occurs only on the level of the origine Work plane
Than I began a new sheet without 3-Pts to chamfer, also only lift the work plane by using the Offset-option, a little bit above the top of the cube.
When I type now the word "TEST" it comes out
- mirroring and
- standing on head
Please have a look to my picture - hardcopy.
Another question:
What is the option " "SET ORIGIN" doing?
I can't recognize any reaction! But I expect that the liftet work plane is going down to the origine level (like Offset minus ..) I'm wrong?
regards
horst.w, GER
Edited by user Wednesday, March 08, 2017 5:53:22 AM(UTC)  | Reason: Not specified
horst.w
#9 Posted : Thursday, March 09, 2017 5:20:29 PM(UTC)
horst.w
Problem will be solved with build 1330, thanks to Tim Olson for sending the pre-version
H.
