2 Pages12>
New Topic Post Reply
#1 Posted : Saturday, February 11, 2017 9:06:42 PM(UTC)
Quote
Was thanked: 157 time(s) in 138 post(s)
Hi All,
We have an early build of SharkCAD Pro 10 ready for beta testing. SharkCAD Pro is renamed from Shark FX.
You can download Mac or PC installer using the link below.
http://www.masterviacad.com/SharkPro10/
Use the link below to Report Bugs and provide Feedback
http://www.punchcadlabs.com/page10/page10.php
Change Log 1338
—Updates to record screen on Windows
—OpenGL wireframe now using vertex arrays
—Correction for unnesscary calculation of silhoutee edges.
—Corrected issue with linary array and grouped objects reappearing on file open
—Removed unused second pass transparency call if in wireframe mode
—Keyshot updates for the update tool
—Corrected issue with abort of DWG read for certain text fragments
—Widen curvature button for localized versoins
—Corrected issue with path align tool and mirror matrix
—Added cm cubed to english volume
—Significantly improved performance of the linery array tool with many copies
—Significantly improved performance of the polar array tool with many copies
—Push/pull now defaults to distance tab for data entry field
—Corrected a crash with point objects within detail views
—Corrected a crash cut/pasting hatches
—PowerPack : Resized spell check buttons
Change Log 1337
—Added drag and drop of Solidworks, NX and Parasolids files to SharkCAD PRO
—Drag/drop STL now convets to the user default unit setting
—Corrected issue where face colors were overiding body colors in STEP export.
—Added ability to export face colors defined with deep select to STEP export.
—Cancel out of Print on Windows no longer displays print error dialog
—Corrected issue with dimension text facets getting scaled by print resolutoin
—Updates to File : Print Window and File : Print now zbuffer's text going using photo render
—Updates to support AVI movie creation on Windows
—Correction to prevent app from multiple launches on Windows
—Movies now support floors
—Correction for resetting object axis position
—Corrected issue display text perp to view but backwards or updside down.
—Corrected issue selecting objects in a draw view layer type which where turned off.
—Adjust size/spacing of auxview layer dialog box.
—Correction to support grouped objects in animation
--Replaced QuickTime in Windows Animation tools
—PowerPack Pro: Added converted X out of Y objects for mesh to analytic tool
Change Log 1335
—Correction displaying align/assembly icons in V9 builds.
—Correction for mirror transform if used in Align tools
—Updated prompt for equally spaced when not enough inputs
—Correction for undo align and solids
—Correction to not display print error if user just cancels on Windows
—Thumb weight edge blending exposed in SharkCAD Pro
—Workplane Grid Settings was not showing correct minor grid values.
—Minor dialog button resizing for French
—Batch File now does zoom extents on imports
—PowerPack : Added new tool Divide tool (boolean intersect that keeps all components)
—PowerPack : Mesh analysis/mesh repair Save as button now working.
—PowerPack : Preview layers now starts from the current work layer.
Change Log 1332
—Display correction on PC for rubber banding box of solid primitives.
—Updates to Inspector and Custom pen styles getting out of sync
—Updates to Inspector and dimension arrow font out of sync
—PowerPack : Feature select and deselect clicks
—Correction to branched surface directions causing issues with booleans and shelling
—PC now saves prefs to SharkCAD Pro folder
—PC menu title name now SharkCAD Pro
Change Log 1331
—Check for all text chars have same extrude direction.
—Multi language string updates
Change Log 1330
—Corrections to Model to Sheet Mac with Precise Option (internal hidden line error)
—Updates to Model to Sheet Polyline option to sort/merge hidden segments into polylines for improved dash spacings.
—Corrected unique crash with polygons from curves.
—Updates/corrections for Compact History
—Projection of a circle/ellipse perp to normal now creates line
—Updates to best fit plane and normal from points
—Correction for attaching Gripper at line object
—Mesh lathe now sets name
—Updated box text size to 10k chars on Mac
—Lathing a solid now checks that the axis is a 2 point line (polyline is invalid input)
—Correction for breaking elliptical arcs at a location.
—Corrected crash with polygon from curves tools and high resolution ellipses.
—PowerPack :Mesh to sphere now has alternative cener calculation for topology poor sphere but correct vertices
—PowerPack : Correction for fitting splines and following hte max angle criteria
Change Log 1329
—Updates to User Guide
—Updates to product name and folder location
—Correction for breaking elliptical arcs at location
—Lathe Solid now checks for valid 2pt line axis
—Correction for crash with Polygon from Curves and high resolution ellipses
—Corrected Tool icons that were out of sync in advanced transform palette when switching between 2D and 3D.
—File Compact correction now removes container solid and updates counts
—Added localization strings for PowerPack Pro
—Correction for the Print By Layers tool on mac
—Widend ambient occulsiont check box for localization
—Update 3DPDF export to now support Selected Only option on file export.
Change Log 1328
—Rename Shark FX to Shark Pro
—Paste values from entity context menu (right click menu) to data entry fields
—Undo of a window into a wall now retrims the wall correctly
—Updated regen procedure
—Correction for doors/windows getting set at different elevations then wall
—Corrected issue with select depression/protrusions/blend networks on PC
—Correction for IGES/STEP imports creating tmp files at unauthorized sandboxed locations
—Correction for the File : Compact tool and groups
—Corrected issue generating facets from linked mirrors
—Photorender materials are now preserved with linked mirror parts
—Layers with linked mirrors now follow the Prefs option for preserving
—Update spline short cuts to have same name as tool palette name.
—The Mesh :Draw menu items are now in sync with main tool palette
—PushPull of a surface object was incorrectly marking the object data only /invisible
—Correction for shell tool and keeping more then 1 face open
—Corrected issue with undo and 1 point circles.
—Magnet tool improvements when using text objects
—UserGuide updates
—Project to plane now supports projecting walls
—Corrected issue of door/widnow not associated with a wall
—Tangencey spell correction in PowerPack
—Correction for dove/tail wood working feature
—Include body transofrm for mate feature
—ViaCAD 2D incorrectly showing 3D wall tools
—Parse .vcp from default file name dialog
—Updated Verify Area and Verify Volume to include a cancel option when selecting many objects.
—Correction for draw view enitties disappearing after a trim operation
Change Log 1327
—Removed used language projects
—Updated UserGuide
—Import IGES/STEP correction regarding tmp files at unauthorized sandboxed locations
—Updates to File Compact for grouped objects
—Corrected issue with Undo and one point circles.
Build 1325
—Corrected issue generating facets display list from linked mirror objects
—Photorender materials are now preserved with linked mirror objects
—Layers with Linked mirrors now follow the user Preference option for preserving layers
—Update spline short cuts now have same name as tool palette name.
—The Mesh : Draw menu items are now in sync with main tool palette
—If text entities are of plane but perpendicular to view, outlines are now drawn instead of trying to calc facets for large performance boost
—Correction for IGES/STEP imports reading to unauthorized sandboxed location for Mac App Store builds (MAC)
—Updated User Guide for eye dropper documentation
—Updated User Guide Index syncing with page numbers
—Updated User Guide table of contents syncing with page numbers
—The STL export Unit drop down required using the arrow keys to access all the unit options. (PC)
—The File : Web Publish option now included in ViaCAD Pro
—Buy Now button added to Registration Dialog box for trial mode
Build 1324
—String copyrights updated to 2017
—KeyShot updates with regens now support improved syncing.
—Magnet tool improvements with using text objects
—Updates for backface mesh selecting
Build 1323
—Corrections for simplify solid and no change status
—Corrections for DWG export abort and ill defined polygons
—Improvements to sillouhette calculations and solid display lists
—Updates to calculating area curve in AeroPack
—Clicking to right of part name in concept explorer now shows display options.
Build 1322
—Slice tool now accepts Groups and Surfaces for slicing.
—Simplify Solid in Powerpack updated for tolerance.
—Feature holes were failing due to wrong normal direction.
Change Log 1321
—Updates for extruding text and small gaps in glyphs from pc
—Increased number of selectable profiles for skinned solids and skinned surfaces
Change Log 1320
—Copy/Paste walls with doors/windows now implemented
—Correction for Edit :Change Resolution and precise option
—Facet calculation correction if threaded implementation fails due to zero polygons in a face
—Correction for repeated facet generation of bad NURB surface (unneeded spinning)
—Undo now does regens only objects impacted by undo
Change Log 1319
—SketchUp 2017 Import now supported
—SketchUP Import now supports Image Entities
—Change Line Style now supported in Context Sensitive Menu
—Change Line Width now supported in Context Sensitive Menu
—Corrected Animation Save
—Corrected crash with selecting walls with undefined window heights
—Corrected extra regen from Inspector
—Correction for transformation grouped ordinate dimensions
—Copy/paste hatches now preserving color/font
—Correction for remove extra hatch resulting from Copy/paste
—Corrected Issue regening polygons derived from curves
—Correction for the Transform along path, align, and stretch icons in 2D
—Correction for drag/dropping symbol into empty file and layer reset
Edited by user Tuesday, April 18, 2017 12:03:35 PM(UTC)  | Reason: Not specified
ViaCAD/Shark Development Team
EvoSoft
Links to ViaCAD Resources
#2 Posted : Sunday, February 12, 2017 12:02:49 AM(UTC)
Quote
Was thanked: 11 time(s) in 10 post(s)
Thanks Tim, that's great news !
Is there any improvement in Model To Sheet tools ?
Many MTS bugs in Beta 1224... some must have been solved.
magicart
#3 Posted : Sunday, February 12, 2017 3:50:13 AM(UTC)
Quote
magicart
Poland
Hi All,
Thank You Tim for the first beta version of Shark v10. It looks really good!
I see some BUGS of Shark fx 1224 build was fixed in Shark Pro. Still some MTS issues not fixed, but I've already reported it.
Could we obtain any informations what features was added into Shark Pro compared to v9?
Have a nice sunday
Magicart
Jean-Francois Jacques
#4 Posted : Monday, February 13, 2017 5:18:10 PM(UTC)
Quote
Canada
Nice Tim....!!!
METEORE DESIGN
Beta Tester Shark FX V9
Platform Mac - Windows 7 (via Apple Boot Camp)
#5 Posted : Monday, February 13, 2017 5:48:39 PM(UTC)
Quote
Canada
Tim, what is the System Requirements for Shark Pro on Mac ???
METEORE DESIGN
#6 Posted : Tuesday, February 14, 2017 9:51:40 AM(UTC)
Quote
Canada
I found my answer....10.8 and greater !!!
I still have LION 10.7.5 because my system is stable and effective. Also, I wait the Mac PRO upgrade to change my main station.
Anyway I can test Shark-Pro on my second station - Mac OS 10.11
Edited by user Tuesday, February 14, 2017 9:52:41 AM(UTC)  | Reason: Not specified
METEORE DESIGN
Claus
#7 Posted : Sunday, February 19, 2017 8:15:55 AM(UTC)
Quote
Claus
Was thanked: 14 time(s) in 12 post(s)
I like the removal of the FX part of the name, but is it called Sharkcad pro or Shark Pro? I think the first rule of marketing is to chose a name that is easy to remember and pronounce. I find Sharkcad to be difficult and vote for Shark Pro. Also I hope the icon it just a placeholder.
As for the program itself there is much to like, looks like a nice upgrade.
Claus
thanks 1 user thanked Claus for this useful post.
flatpack on 3/7/2017(UTC)
thefro
#8 Posted : Sunday, February 19, 2017 11:46:07 AM(UTC)
Quote
thefro
Nice upgrade
find the icon a bit non descript, I would not associate it with Shark straight away (looks like a fin but thats all) I prefer a shark on a red background stands out in the doc on Mac more.
Brian
Edited by user Sunday, February 19, 2017 4:52:26 PM(UTC)  | Reason: Not specified
Antoine
#9 Posted : Tuesday, February 21, 2017 3:18:24 AM(UTC)
Quote
Antoine
Switzerland
Was thanked: 15 time(s) in 10 post(s)
Hello All,
* Updated draw views for layers, panning, zooming
* 3D PDF Export
* 3D Print Tool palette
* Updated ACIS modeling kernel
* Updated Translators (STEP, IGES, SAT, SAB,DWG)
* Updated Translators PC Only (SolidWorks, SolidEdge, CATIA, ParaSolids, NX,ProE)
• Multithreaded faceting and file imports (SAB, STEP, IGES)
* Custom Right Button
* Gripper at Selected option
* Recall Backup in File menu
* Keep Original Layer on Copy option
* Updated Bill of Materials (number of decimals, font type specify)
* Dynamic zoom and pan within a draw view
* Repair curve tool
* Magnet Tool
* More subdivision tools
* Pocket Hole feature
* SketchUp 2017 Import/Export
* SAB Export
* STL Export Improvements
* KeyShot Live Linking ---> good but bugged
* Infinite Plane display update
* Rapid Render Wood
* Faster repaints
* Language support for English, French, Italian, and German
Hello Tim,
Thank you for your efforts on this update.
But I am quite disappointed with this update, which is meant to be major.
I put in green the themes that are most useful to me in my workflow.
I am very disappointed by the lack of interest of Punch! Concerning the optimization of the MTS Module.
As repeated for more than 10 years, this mode of technical drawings 2d is absolutely unusable in a professional environment, with a normal production flow.
For example:
The bugs in the interpretation of the mode 3d in 2d:
Hidden lines
Tangent lines
Worse, it is impossible to trust in Shark to realize a 2d proffessional technical plan without errors.
I spend too many hours! To correct drawings and attributes of custom lines.
!!For me Shark is really good about 3D modeling!!
It only needs one MTS mode redesigned in depth.
Either I am the only one to ask for this level of performance, or there are not enough users who want to complain about this state.
Thank you
www.dayer-design.ch
www.design-r.ch
SharkFX 9
MacOS 10.12.3
Mac Pro 2 x 2.93 GHz 6-Core Intel Xeon
ATI Radeon HD 5870 1024 Mo
thanks 3 users thanked Antoine for this useful post.
L. Banasky on 2/21/2017(UTC), GARLIC on 2/21/2017(UTC), magicart on 2/21/2017(UTC)
magicart
#10 Posted : Tuesday, February 21, 2017 11:36:49 AM(UTC)
Quote
magicart
Poland
Hi Antoine,
I noticed that MTS works quite good if there is no interference in Your model (verify -> interference), but generally I agree - to much bugs in this most needed module.
One what I have to say is the 3dpdf export in v10 is now very serious improvement (in v9 was useless).
Magicart
#11 Posted : Tuesday, February 21, 2017 2:05:26 PM(UTC)
Quote
>>MTS Module
We're aware and looking into. We had a conference call last week with Spatial that included discussions about MTS. MTS is based on licensed technology from CATIA via Spatial.
EvoSoft
#12 Posted : Wednesday, February 22, 2017 4:15:28 AM(UTC)
Attach Quote
Was thanked: 10 time(s) in 10 post(s)
It would mean that Catia would have the same bug ????
It's impossible....
Antoine
#13 Posted : Wednesday, February 22, 2017 4:25:40 AM(UTC)
Quote
Antoine
Switzerland
Hello,
For example:
https://www.screencast.com/t/ucwQ86By
Thank you
Antoine
www.dayer-design.ch
www.design-r.ch
SharkFX 9
MacOS 10.12.3
#14 Posted : Wednesday, February 22, 2017 1:33:38 PM(UTC)
Quote
Spatial took the CATIA library and added a bridge to interface between the CATIA geometry engine and the ACIS engine. The error is likely with the bridge created by Spatial.
The CATIA v5/v6 native imports in Shark are integrated the same way. They use the actual CATIA libraries but provide a bridge back into ACIS. It is the same libs you find if you install CATIA.
EvoSoft
David Gross
#15 Posted : Thursday, February 23, 2017 3:00:08 PM(UTC)
Quote
David Gross
Now that V10 is in the beta stage dose this mean that V9 build 1224 is the last V9 update?
David Gross
Dmg Design
Colgate, Wi.
#16 Posted : Monday, February 27, 2017 2:00:39 PM(UTC)
Quote
No. When SharkCAD V10 is released, then Encore asks us to stop releasing previous version builds.
EvoSoft
Antoine
#17 Posted : Tuesday, March 07, 2017 4:43:37 AM(UTC)
Quote
Antoine
Switzerland
Hello Tim,
Unable to launch the software after installation.
SharkCAD 10 1330
Antoine
Edited by user Tuesday, March 07, 2017 4:44:54 AM(UTC)  | Reason: Not specified
Antoine attached the following image(s):
www.dayer-design.ch
www.design-r.ch
SharkFX 9
MacOS 10.12.3
GARLIC
#18 Posted : Tuesday, March 07, 2017 6:19:18 AM(UTC)
Quote
GARLIC
I couldn't start Shark 10 Beta 1328 either - WIN 7-64 Pro
parts of the shark installer-prerequisites are:
vcredist_x64.exe
vcredist_x64_2012.exe
vcredist_x64_2013.exe
vcredist_x64_2015.exe
one of these 4 installers caused the problem, sorry all the logfiles have been deleted.
I tried the to fix the installer probs with the MS tool: NetFxRepairTool
but to no avail, also running
sfc /scannow
revealed any solution.
I am wondering if there is any suitable workaround ?
thanks + regards
G.
#19 Posted : Tuesday, March 07, 2017 10:01:21 AM(UTC)
Quote
Hello Antoine
Can you replace your Strings folder with the attached folder?
Strings.zip (88kb) downloaded 7 time(s).
EvoSoft
#20 Posted : Tuesday, March 07, 2017 10:03:34 AM(UTC)
Quote
>> vcredist_x64.exe
Those are the Visual Studio redistributable from MicroSoft. These should be the same as in ViaCAD Pro 10, are you having issues with ViaCAD 10 as well?
Did it give you any other error message?
EvoSoft
Quick Reply Show Quick Reply
2 Pages12>
You can post new topics in this forum.
You can reply to topics in this forum.
You can delete your posts in this forum.
You can edit your posts in this forum.
You can vote in polls in this forum.
