Import/Export
Wavefront obj file and X-Plane obj8 file
                Hi there, I was trying different export files to which one would work in AC3D. So I could use the X-Plane plugin for AC3D to create an X-Plane .obj8 file to use in building scenery objects. Currently I have X-Plane 10.51 and X-Plane 11 Beta2 installed. Different programs can have their own .obj file such as X-Plane which are not suppor to be compatible with Wavefront Obj file. So I was surprised and puzzled that when I exported a test object such as a box, torus, cone as a Wavefront .obj file to a document folder (anywhere) the objected saved as an "X-Plane 3D Object". Why. See
http://developer.x-plane.com/ under  "Documentation. Have attached a screenshot of the  folder with the wavefront .obj files.
KSimmons attached the following image(s):
(34kb) downloaded 12  time(s). You cannot  view/download attachments. Try to login or register.
                 Hello The files export out as .obj files.  If you have a program associated to open these then it will display as that type of file.  If you display the file extension it should be .obj  I would guess that the operating system is just associating the .obj with X-Plane 3D object. In Win 10 i have the app called 3d builder installed and it associated the .obj to that program and uses its icon image for the file. Regards Jason
Import/Export
