macyone
#1 Posted : Tuesday, October 11, 2016 10:55:41 AM(UTC)
macyone
My pictures are very pixelated. How can I change this? Thus the renderings are not to be used.
#2 Posted : Tuesday, October 11, 2016 2:47:43 PM(UTC)
PhotoRender uses the display resolution.
1. The Edit : Change Resolution : Super Fine : Precise Facets command will give you the highest resolution using defaults.
2. Prefs : Custom Resolution allows you to override the resolution settings for Fine, Medium, Super Fine etc
3. Edit : Change Object Type : Mesh, set facet parameters, then cancel. Be sure to cancel. When you cancel, the mesh is applied as the display list of the surface/solid. This gives you complete control of the display faceting.
I'll see if I can add this to the v10 tips book with some descriptive images.
Edited by user Tuesday, October 11, 2016 2:48:33 PM(UTC)  | Reason: Not specified
macyone
#3 Posted : Wednesday, October 12, 2016 2:35:49 AM(UTC)
macyone
Thanks, i try this asap.
macyone
#4 Posted : Wednesday, October 12, 2016 2:44:45 PM(UTC)
macyone
Hi Tim,
Unfortunately I can not follow your instructions. I have a German version I can not start with the info. Can you post me a few Screeshots. Basically, the resolution must be adjusted when rendering! Or is it only in international not possible?
#5 Posted : Wednesday, October 12, 2016 3:46:07 PM(UTC)
Select the object you want to increase resolution and then pick the Edit : Change Resolution command and set to SuperFine and Precise.
