Is ViaCAD Pro 9.0.9 Build 1184 ready for MacOS Sierra?
VIACAD PRO is so important to my work that I would not to upgrade MacOS, if not ready. Are there still issues that must be resolved before the green light to upgrade? Thanks
Encore QA is testing a build of ViaCAD 9 now as a service pack update. It does have a correction for Window tab issue in Sierra that was appearing in preview builds. I just sent and email to Encore Tech support to see if they have had any reports. Tim
FYI, so far no issues have been reported to Tech Support regarding Sierra. Tim
I recently upgraded to MacOS Sierra and ViaCAD Pro (build 1184) has stopped working. I can start the program but can not open an existing drawing or start a new one, it just sits there until I force quit.
Has anybody else experienced this problem and do you have a solution?
Oscar Erickson
FOLLOW-UP: I just learned a work-around. If I open ViaCAD and THEN try to open a file (or create a new file) it hangs at "updating curve display list" and I have to force quit.
BUT if I double click on a .vcp file to start ViaCAD it will open the file and I can then open and close other files. I haven't done extensive testing on that but it worked several times.
Edited by user Wednesday, September 28, 2016 8:05:34 PM(UTC)
| Reason: Found a work-around to the problem
Hello Oscar I would recommend contacting Encore tech support. I'll forward your post over to them as well and see if they have heard of this before. Tim
