jlengineering
#1 Posted : Thursday, July 7, 2016 10:13:36 PM(UTC)
jlengineering
I'm having trouble with dfx files. If I get emailed a dfx file and I open it in viacad. After I make any modifications to it and export it as a new dfx, when I go to open it in Sheet Cam all that shows up is the new lines that I have drawn as part of the modification. It seems the original image isn't there. Is there a way to do this or do I have to redraw the image as that is what I have been doing?
Edited by user Thursday, July 7, 2016 10:15:15 PM(UTC)  | Reason: Not specified
#2 Posted : Thursday, July 7, 2016 10:30:56 PM(UTC)
Jl
I would look and see what layers things are on. What happens if you open the file again in viacad?
Sounds like layers or colors issue
jlengineering
#3 Posted : Thursday, July 7, 2016 10:36:53 PM(UTC)
jlengineering
actually when I first open it in viacad before and after modifications to the image, the original image is a lighter color than the new lines. I can select the image, even erase lines but the original image still is a lighter more faint color.
#4 Posted : Friday, July 8, 2016 6:29:21 AM(UTC)
Try
Importing your original dxf file, make sure all objects are on visible layers or move all to a new layer that has a pen color thats is the same, and try exporting again.
jlengineering
#5 Posted : Friday, July 8, 2016 7:33:00 AM(UTC)
jlengineering
I will try that. Thanks for your help
jlengineering
#6 Posted : Monday, July 11, 2016 4:01:41 PM(UTC)
jlengineering
Ok, that worked! Thanks for the help on that. Maybe you can help me out with another issue. When using the arc tool, how do I make it so the arc is more round and not segmented. It looks as if it's point to point and not a true arc.
