2D Drafting
Please Help close the contours
Hi
I have a dxf and would like to close the contours. I'm now the whole sunday on this piece.
How do i close the contours from an imported dxf?
Please help!
Thank's a lot
Andy
Edited by user Sunday, May 1, 2016 12:27:52 PM(UTC)
quadSchutzring2mmR12.dxf
(165kb) downloaded 33 time(s). You cannot view/download attachments. Try to login or register.
HI Andy
Nice file! I used PowerPack to find and remove the overlaps, duplicates, and gaps. A .vcp file is attached with repaired profile and extruded solid.
Do I have permission to use the file to make a video how PowerPack can be used to repair profiles for my masterviacad.com site?
Edited by user Sunday, May 1, 2016 1:28:35 PM(UTC)
profile.vcp
(1,020kb) downloaded 19 time(s). Tim Olson attached the following image(s):
(343kb) downloaded 33 time(s). You cannot view/download attachments. Try to login or register.
Thank you soo much! Of course you can use it! Andy
H Tim
May you can do the same for the second (last) file?
that would be great!
Thank's
Edited by user Sunday, May 1, 2016 4:21:04 PM(UTC)
quadSchutzring1_5mmR12.dxf
(228kb) downloaded 17 time(s). You cannot view/download attachments. Try to login or register.
Hi
Why is it not possible to push this 2D design? How can i find out where the problem is?
I'm still have problems to understand why often i have difficulties for 2D Sketches to extrude (Push) in ViaCAD....
Thank's a lot
Andy
quad.vcp
(265kb) downloaded 16 time(s). You cannot view/download attachments. Try to login or register.
Thanks: 630 times Was thanked: 102 time(s) in 65 post(s)
Morhin: the problem is "profile overlap" and the error message reads: "Overlapping curves detected in profile.Remove the curve and try again" So you have to check your profiles again............ Regards
Originally Posted by: GARLIC Morhin: the problem is "profile overlap" and the error message reads: "Overlapping curves detected in profile.Remove the curve and try again" So you have to check your profiles again............ Regards
On the previous file "quad.vcp" i have testet with the powerpack beta
->verify->overlaps
->Result: "Examined 126 entities. No overlap entities found"
So it should soemthing other, shoudn't it?
thank's
Andy
Sorry Morphin, I should have told you that I used the extrude function only with the resulting overlap error message, regards
Hi Did you manage to extrude the file on post 5? If yes how? thank you very much Andy
No, I didn't succeed to extrude #5. I had removed one overlapping line but to no avail, same error message.. Sorry, I do not have more time to dive into every detail. Regards G
Originally Posted by: Morphin Hi Why is it not possible to push this 2D design? How can i find out where the problem is? I'm still have problems to understand why often i have difficulties for 2D Sketches to extrude (Push) in ViaCAD.... Thank's a lot Andy
Andy
It might be better to look at how these files are being created and saved as dxf. Are they created in ViaCAD or another 2d or 3d program?
I found several areas that had duplicate lines in the profile.
For the file you attached you have to remove the groups so the powerpack tools can find the overlaps
There is also some extra lines
Edited by user Monday, May 2, 2016 9:21:28 AM(UTC)
(92kb) downloaded 13 time(s). You cannot view/download attachments. Try to login or register.
There is also bad geometry in the file as well
See pic.
(25kb) downloaded 9 time(s). You cannot view/download attachments. Try to login or register.
Thank you very much
I will have a look. I had made the DXF with LibreCad because i know it more the ViaCAD Pro. But it seems that LibreCAD has a few bugs...
Andy
O.k. I found corrected all the things i have found. i have also ungrouped, but i'm still not able to extrude.
I'm very grateful if somebody may help me further...
Thank you very much
Andy
Edited by user Monday, May 2, 2016 12:00:45 PM(UTC)
quadSchutzring2mmR12V3.vcp
(401kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
It works!!! Interesting. I have selected everything and changed object-type to polygon (it was already on polygon!) and now it works.... Thank's Andy
Hi Andy
I removed the duplicates, fixed the overlaps, and repaired gaps using PowerPack's repair profile tools. Attached is the repaired profile and solid.
I'll show the specific tools in the video tip I'm making. These are awesome profiles.
profile2.sfx
(1,568kb) downloaded 13 time(s). Tim Olson attached the following image(s):
(285kb) downloaded 12 time(s). You cannot view/download attachments. Try to login or register.
Great Thank you very much I just also managed to repair it.. Andy
I don't own the Powerpack, and am running into the same thing in attempting to revolve a 2D part. Knowing that there might be tiny overlaps or gaps, I went over the drawing in Autocad 2007 using Plines and closing to the beginning point. There should be absolutely no gaps, but I'm still getting this error message.
Can someone take a look at my file and see what is going on? (Need to figure out how to attach my .vcp file)
Dan
JD950.vcp
(145kb) downloaded 8 time(s). You cannot view/download attachments. Try to login or register.
.vcp drawing
JD950.vcp
(145kb) downloaded 6 time(s). You cannot view/download attachments. Try to login or register.
HI Dan
There is a duplicate curve in the profile. I was able to find and repair using the Repair Curves tool in V10.
(75kb) downloaded 4 time(s). You cannot view/download attachments. Try to login or register.
Thanks, Tim. I've been wondering if I should upgrade to 10. Sounds like I'm going to need to do that. Dan
2D Drafting
