Antoine
#1 Posted : Wednesday, February 24, 2016 4:18:30 AM(UTC)
Antoine
Switzerland
Was thanked: 31 time(s) in 25 post(s)
Hello Tim,
How can I weld that blue surface on the green volume please?
Thank you.
Antoine
velo.sfx (146kb) downloaded 12 time(s).
Antoine attached the following image(s):
Capture d’écran 2016-02-24 à 11.14.25.png (236kb) downloaded 10 time(s).
mrconcepts.ch
design-r.ch
SharkFX 10
MacOS 10.13.6
Mac Pro 2,7 GHz 12-Core Intel Xeon E5
AMD FirePro 6144 Mo
Antoine
#2 Posted : Wednesday, February 24, 2016 4:26:45 AM(UTC)
Antoine
Switzerland
There is the solution to convert all surfaces, then weld it all with the tool: Stitch.
But I would like a simple solution, if it exists.
Capture d’écran 2016-02-24 à 11.24.08.png (187kb) downloaded 12 time(s).
mrconcepts.ch
design-r.ch
SharkFX 10
MacOS 10.13.6
AMD FirePro 6144 Mo
#3 Posted : Wednesday, February 24, 2016 11:34:19 AM(UTC)
Was thanked: 234 time(s) in 203 post(s)
Hi Antoine
Do you need the previous underlying blend? It looks like they share the same space. If not, remove the blend with deep select and then do a Solid Boolean Add with the surface.
Edited by user Wednesday, February 24, 2016 12:04:35 PM(UTC)  | Reason: Not specified
Vice President Software Development
