Thanks: 103 times Was thanked: 18 time(s) in 14 post(s)
Any subdivision volume I create seems to be invisible. I can "see" its points only when I select it. Here's a snapshot to show. My pen and fill colors are set to Black. I tried restarting to no avail. Please advise what could be wrong.
(536kb) downloaded 27 time(s). You cannot view/download attachments. Try to login or register.
ALso I just realized that when I create a solid volume, like a block primitive for example and Change Object Type to a Mesh, the outcome is also an invisible object. Only can be seen when I drag-select over it and the points show up. Just the points - no object. By the way I am using Shark LT v9.
Thanks: 594 times Was thanked: 97 time(s) in 63 post(s)
What are your settings under View/Shade Options for: Static Shade ? Dynamic Shade ? Shade Now ? Please check these setting... best wishes !
1 user thanked GARLIC for this useful post.
Originally Posted by: GARLIC What are your settings under View/Shade Options for: Static Shade ? Dynamic Shade ? Shade Now ? Please check these setting... best wishes !
Absolutely! That fixed it. Everything was set to "hidden with dimmed" which seems to show the other solid objects fine, but no SubD volumes. Thanks a million Garlic.
You might want to check your color assigned to mesh edges. They might be white.
Prefs: Display : Surface : Edge Color
TIm
Edited by user Monday, January 4, 2016 10:05:04 AM(UTC)
(129kb) downloaded 10 time(s). You cannot view/download attachments. Try to login or register.
