I am unable to print from ViaCad. Printer will print fine from other applications but not ViaCad. I am running ViaCad 2D/3D V.9.0.4, build 1166. I am running WIN10 64 bit Home version with 4 gig of RAM. My printer is hooked up via wireless router connection. When I go to print layout it shows in spooler but never prints. I belive it may have something to do with the 3D views. Does anyone have any insight into this? I can save as BMP and print but resolution is not as good. I am hoping someone has a solution. Thank you in advance for your assistance!
Are you able to create a simple line (no solids/mesh/surfaces) and print? Tim
Yes I am able to print simple lines.
Edited by user Wednesday, December 23, 2015 11:44:42 PM(UTC)
If you can email me the file, I can check if it is a general software type of error and not a print driver error. Tim
Originally Posted by: CNW I am unable to print from ViaCad. Printer will print fine from other applications but not ViaCad. I am running ViaCad 2D/3D V.9.0.4, build 1166. I am running WIN10 64 bit Home version with 4 gig of RAM. My printer is hooked up via wireless router connection. When I go to print layout it shows in spooler but never prints. I belive it may have something to do with the 3D views. Does anyone have any insight into this? I can save as BMP and print but resolution is not as good. I am hoping someone has a solution. Thank you in advance for your assistance!
Hello
Can you try printing to pdf or or microsoft xps.
Jason,
Thank you for the response. I can print to XPS or PDF but the files do not look right. I have attached a file for your review. Thank you.
TEST.pdf
(794kb) downloaded 21 time(s). You cannot view/download attachments. Try to login or register.
I have seen that issue printing to a printer, but not to pdf files. I can print fine to pdf file, but not to a physical printer with V9. Using win 10 and printing to wireless printer. Tried printing from win 7 with V8 and its fine, but tye difference is windows versions and ViaCAD versions.
http://forum.punchcad.co...sts&t=7506#post28074 Regards
Edited by user Monday, December 28, 2015 8:21:02 AM(UTC)
