Cutting Curves with a Surface (#3691)
I would like to split the curves in the attached picture with the blue surface, or sometimes with the surface of a solid.
Can anyone please tell me if, or how this can be done with the tools in ViaCAD?
Martin.
(124kb) downloaded 0 time(s). You cannot view/download attachments. Try to login or register.
I don't think you can cut through a curve with a surface. You can close the curve with a line in your case and make a surface from a closed profile and duplicate the new surface in an array. After that, then you can do intersect surfaces with a plane or with your current drawn surface to get the intersection of two surfaces thus given you a cut profile. There's also the curve/surface intersect tool which would give you points to where the curve intersects with the surface.
