#1 Posted : Wednesday, June 11, 2008 10:10:15 PM(UTC)
QT video showing the assembly tools created by Nick Johnson our UK Shark distributor.
http://www.cadsoftsolutions.co....s/connect_mate_align.mov
markb57
#2 Posted : Monday, June 16, 2008 11:00:53 PM(UTC)
markb57
Thanks for the good work!
markb57
ttrw
#3 Posted : Monday, May 18, 2009 4:20:09 PM(UTC)
ttrw
Tim, Nick, (Steve?)
I've been trying to get the following two parts to mate together- but have had no luck so far. Okay, it needs a pin or something to hold it there, but I was trying for a basic concentric mate, but can't get Shark to do anything (apart from give me an error, about surfaces needing to be planar).
Can either of you help, or someone else want to chime in?
Fwiw, I can get one basic mate to work- the face to face mate- but that's all.
The two bushes may not be the same diameter (where's the tape measure? - ah yes... they're not. Does that matter? :confused:)
Tom
Pulley and Mount assembly.slt (275kb) downloaded 5 time(s).
mating difficulty.jpg (11kb) downloaded 6 time(s).
#4 Posted : Monday, May 18, 2009 4:38:34 PM(UTC)
LOL! The subject alone made me think of the earlier BB spam comments.... hehehehe
Maybe CAD really IS an organic process...
Steve.M
#5 Posted : Monday, May 18, 2009 5:10:07 PM(UTC)
Steve.M
Hi Tom,
Are you trying to align as shown in the pic?
If yes, then one way to do that:- use "Align Faces" and click the inside face of each hole, then use "mate faces" to align the 2 mating faces.
- Steve
ttrw
#6 Posted : Tuesday, May 19, 2009 1:32:55 AM(UTC)
ttrw
Steve, a Gent, like usual! :D
Thanks!
ttrw
#7 Posted : Tuesday, May 19, 2009 3:22:45 AM(UTC)
ttrw
Steve, dunno if you can see this, but here's what I was trying to do (minus pin).
It's taken me a whole day to do what I would normally do in an hour (if I were using Solidworks). But I'm learning- fast.
I'll mention this here, but I'm going to bring the same thead up in the beta section;
Tim, It's somewhat annoying that when a part is imported into an assembly, it comes in as a "part_362062..etc" part rather than the actual name of that part- which is highly frustrating because I just have to rename the part again. This has got to be a bug, because it is named properly in the layer manager! (see attached pix) :mad:
Picture 6.png (38kb) downloaded 5 time(s).
Picture 7.png (24kb) downloaded 5 time(s).
