SG2009
#1 Posted : Sunday, November 7, 2010 8:28:18 AM(UTC)
SG2009
I have the attached model and I would like to stitch the far leg, which is a group of surfaces, into a solid so that I can bend it.
I solved the problem by deleting surfaces and extruding it into a solid, but I would like to learn how to do it by stitching as well.
I can't seem to close the volume properly. I have tried adding various types of surfaces over the open end but I can't come up with the correct recipe.
Thanks for your help. I use ViaCADPro V6
TO-247.vcp (138kb) downloaded 4 time(s).
#2 Posted : Sunday, November 7, 2010 9:38:28 AM(UTC)
Hi
Try this
1. Ungroup surfaces
2. Cover tool pic the 4 edges to cover
3. Stitch tool make sure to go to options of the tool and pick closed volume required box. Pick all the surfaces
TO-247_stiched.vc3 (101kb) downloaded 4 time(s).
SG2009
#3 Posted : Sunday, November 7, 2010 10:32:44 AM(UTC)
SG2009
Thanks Jason. I had tried net surface and skin surface before I gave up.
