The Replace function in the Feature Tree is great. I use Replace Curve all the time. Now, 2007, I would like to see this extended into: - Replace Profile - Replace Surface - Replace Solid This would make modeling with CU sooo much easier, faster, more flexible. Thanx!
>>- Replace Profile Love that idea!!! - Replace Surface Yes very good! >>Replace Solid As in a boolean operation? Wow, great ideas, very implementable, many thanks!
Orlando deserves a bear for that !:rolleyes: In case the replaced solid is used in a model to sheet, will it update the views and the dimensions ? (Today, when I deeply modify a solid, I have to start again the MTS from scratch). Thanks, JL
