ISS
#1 Posted : Tuesday, April 21, 2009 6:58:48 PM(UTC)
ISS
Hi, my name is Norbert but in order not to confuse me, a newbie, with the other, very knowledgeable Norbert, I will sign Norbert M.
I have a problem with differential 2D scaling ....
Let's assume I am talking about a door of a kitchen cabinet to be processed by a CNC router. This door has decorative routing around the periphery and also has arched grooving to resemble a raised panel door. The dimension of this door is 500mm wide and 700mm high and the door panel as well as the routings are all on 1 (ViaCAD)layer.
Let's also assume that this particular design can handle variatons in width (or height) without looking distorted.
Now, apart from the standard 500 wide doors I need one or two doors of a slightly different width, say 457mm instead of the the standard 500mm.
Rather than redesign the door from scratch I would like to be able to load the 500mm door, change the appropriate axis from 500mm to 457mm and send the dxf file to the machine control program.
Suggestion(s) anyone?
#2 Posted : Tuesday, April 21, 2009 8:42:36 PM(UTC)
Hi, Norbert
Select the whole door --> pick scale tool --> change your drop down box at the top from uniform to differential and enter in the value 457/500 right in the x if that's the width direction or y whichever you are using do not hit enter.
and leave the other axis as 1 if you do not want to scale that axis and then pick a point on the bottom left corner of the door and its should scale as you need.
ISS
#3 Posted : Wednesday, April 22, 2009 7:15:58 AM(UTC)
ISS
enter in the value 457/500 right in the x if that's the width direction ...
Thanks Jason, that works very well :)
