misterrogers
#1 Posted : Monday, January 17, 2011 7:07:54 PM(UTC)
misterrogers
Can one select multiple layers somehow? For example to move easily into "Sub-layers" under one new layer name?
Sorry if this has been asked before..
NickB
#2 Posted : Tuesday, January 18, 2011 2:14:35 AM(UTC)
NickB
Short answer: No.
You can not make more than one layer active in Concept Explorer / Layers.
Long answer: Sort of.
If you use the Select Mask, you can select multiple layers to be active, or deselect the layers you don't want. You can then do a Select All to select all the entities on the various layers you want to move, and either use the contextual menu / layer option, or the Inspector to change all the entities to the destination layer that you want.
Shark FX 9 build 1143
OS X 9.5
matter.cc
misterrogers
#3 Posted : Tuesday, January 18, 2011 7:33:42 PM(UTC)
misterrogers
Originally Posted by: NickB Go to Quoted Post
Short answer: No.
Thanks Nick, never thought of using the Select Mask for layers. Clunky, but certainly faster than one-at-a-time!
btw my sister lives out in SF too. Great city - excellent food!
