L. Banasky
#1 Posted : Tuesday, October 30, 2012 10:13:25 AM(UTC)
L. Banasky
When doing a Model to Sheet, using "Best Fit" for scale, the hidden lines are not the correct scale.
If I change the scale of each views properties, and then UNDO the change, the scale is correct.
This is on SharkFX 8 1016 Win 7 64. I 'm not good with videos, so pics will have to do, sorry.
Thanks, Larry
Model to Sheet Settings.JPG (67kb) downloaded 5 time(s).
Before Scale Change.jpg (36kb) downloaded 5 time(s).
After Scale Change.jpg (41kb) downloaded 5 time(s).
After UNDO Change Scale.jpg (38kb) downloaded 5 time(s).
