klais
#1 Posted : Friday, August 20, 2010 6:10:57 PM(UTC)
klais
All of the control symbols and modifiers are missing when I attempt to use GDT tool.
#2 Posted : Monday, August 23, 2010 10:18:16 AM(UTC)
Hello Klais
I seem aok here. It sounds like the GD&T font is not installed. If you send me your email address, I can send you the 946 build to test?
[email protected]
klais
#3 Posted : Tuesday, August 24, 2010 9:04:17 PM(UTC)
klais
Hi Tim,
Still no joy with build 946.
klais attached the following image(s):
Screen shot 2010-08-24 at 6.22.05 PM.png (50kb) downloaded 5 time(s).
klais
#4 Posted : Wednesday, August 25, 2010 9:54:50 AM(UTC)
klais
Hi Tim,
I suspect this problem is related to running my MacPro in x64 mode. I installed Shark FX on my laptop, which can only run 32 bit, and the fonts show up even running the software in demo mode.
Best regards,
Kevin
#5 Posted : Wednesday, August 25, 2010 1:55:38 PM(UTC)
Kevin
Does the PunchGDT.ttf font exist on your machine?
If not, try unzipping the attached file and placing into your /Library/Fonts folder.
PunchGDT.ttf.zip (9kb) downloaded 9 time(s).
klais
#6 Posted : Wednesday, August 25, 2010 9:18:28 PM(UTC)
klais
Thanks Tim, that took care of the problem.
