#1 Posted : Friday, May 15, 2009 1:28:45 PM(UTC)
Hi Tim
When objects are selected and you right click you get the view/zoom/workplane/select menu, which is the same if you right click not on an object.
If you right click on a object you get the color layer etc menu. which also give the properties of an object. but will only modify the object you right click on (not Multiple if chain selected)
When an object or objects are selected or chain selected why not have any right click go to a contextual menu with line type thickness layer color or font font height etc so you don't always have to run your mouse to the file menu at the top or hit a key command?
The goal is to be able to select multiple items and change properties with a right click menu like color layer linetype lineweight linetype scale font font height etc?
