2D Drafting
Nasty bug in model to sheet mode (#3918)
Open a 2 D drawing (model to sheet). Select a view. Type "shift-arrow" (as if you think of nudging the view)... ---> all views get empty ---> Impossible to undo ! Don't forget to close the file WITHOUT saving....
Hi JL Draw views are only visible when in the top view. Hitting Shift arrow will rotate the current view. Just hit the Top view and they contents of the draw view will be visible. Regards Tim
Thanks: 39 times Was thanked: 30 time(s) in 23 post(s)
actually, it seems that you are turning the view, that make looks that the lines get vanished, l select top view and you will see all your draw again. Luis G.
Thanks Tim, Thanks Luis, I just discovered a way to rotate... I'm still learning...
>>I just discovered a way to rotate... I'm still learning.. Ditto I forgot about it and when I hit Shift Arrow said UGH! Took me a few minutes to realize the view changed:) Tim
2D Drafting
