quitting viacad... (#1468)
                Hi guys,
  I'm not sure if this is a bug or what, so I thought I would just mention it and see what happens!!
  When I hit apple-Q to quit, the usual box pops up with three buttons in it.  The rh one is "Save", next to it is "Cancel", and most left, "Don't Save".  Because the "Save" button is default, it is filled blue.  When I use the tab key to go to "Don't Save", this button is surrounded by a blue border, and if one tabs again, this border cycles through the three buttons, but the "Save" button stays filled.  When the return key is pressed, the "Save As..." window pops open, regardless of which button is highlighted with the blue border (which I think should indicate the selected button).
  Is it better to post things like this here on the forum, or direct to tech support?
Regards, Ian Kirby.
Wollongong NSW Australia
ianjkirby attached the following image(s):
(20kb) downloaded 4  time(s). You cannot  view/download attachments. Try to login or register.
    Ian Kirby  Wollongong Australia
