enkeboll Molding (#1859)
                http://www.enkeboll.com/2DLA/start.htm I am trying to miter there moldings and change the sizes to go around cabinets.Could someone show me if I can do it in ViaCad-6
Here is a Drill Press I just made in ViaCad
Thank You
 Redds
Redss attached the following image(s):
(18kb) downloaded 1  time(s). You cannot  view/download attachments. Try to login or register.
                Hi, Redss
Nice job with the drill press.  See attached file with a molding example.
 mold.vc3
(1,314kb) downloaded 1  time(s). You cannot  view/download attachments. Try to login or register.
                Hey jdi000, when I tried to open your file, I got a message saying the file was damaged and that it would not be opened. Currently, I have ViaCAD V5.  Is this file from a newer version and will ViaCAD files not open in older versions?
                Hi, mlochala
The file was created in Version 6.  Here is version 5 file.  You can export any version out so older versions can open files if you need to.
 moldv5.vc3
(1,313kb) downloaded 1  time(s). You cannot  view/download attachments. Try to login or register.
                Is the height the same, but the profile different on what you want to match?  It may work to do the following Combine two pieces of molding into one part (two solid bodies) Remove the end face on both (use shift because it must be done simultaneously) The resulting stitched up solid is then split where the two meet.  However, if the profile is different, I don't think a flat plane will work. Edit: I tried this and it doesn't work.  However, if I put down a block primitive (keep a duplicate for later) for both pieces of molding, merge it with the two pieces of molding into one solid part, I can then remove some faces (the end of each piece of molding, and two faces on the block).  The stitching will then work, and I can then remove the block primive by subtracting the duplicate.
                Thank You ereyone My computer is down stoped working Sunday morning. A guy came in Monday and put he's analyzer program on it. He said it was 50/50 it could be the motherboard or graphic card. By reading the computer I new it was one or the other and I don't know how to open the back of a computer.I had to pay $100.00 for one hour it took him 7mi to do it:confused:He said for $175.00 he would put a new graphic card in it. He said if it is not it there will be no charge:rolleyes: I need a new computer any way the one just 1G. It looks like I need a 4G or more and a top grade graphic card:eek:I do alot of graphic with my 4 Cad programs. I hope to be back up by next week.I am loseing work I design custom homes.My son's said if I can not do the design they have to get some that can do them:mad:
