Found the tips on Shark Attack very easy and informative as a new user, any chance in having them once or twice a month?
I added another entry today to the blog regarding Object Resolutions.
http://blog.punchcad.com/?p=445#more-445 Tim
Thanks you for taking the time for this type of info. Found it very interesting as a new user.
Tim, you say that 'fine' uses an angular deviation of 11 degrees. Then you go on to say 'medium' uses an ang dev of 11 degrees in your table
Fixed, thanks for the heads up! Tim
Tim, not sure if these Shark Attack tips are made by yourself or others, but I would really like to see extended tips on all the Constraint tools (some have been made by Mikeschn) .
Also I am not familiar with the following Surface tools. Any sort of basic demo of them will be very valuable.
Thanks.
misterrogers attached the following image(s):
(14kb) downloaded 5 time(s). You cannot view/download attachments. Try to login or register.
