Dynamic Rotate Shortcut (#4068)
I'm a new user, but I am 99% sure that for the first 5 times or so that I used VC, the option key on my mac was a shortcut for Dynamic Rotate. For some reason now, it is a shortcut for Zoom Window ?!?! Am I crazy? Is there a way to set it back to the ber useful dynamic rotate? thanks! S_
You can set / reset the shortcuts in the File menu Click 'shortcuts' and a dialog box will appear
Other ways to rotate the view: --Press and hold middle button --Shift arrow keys (with nothing selected) --Assign a short cut to the Dynamic Rotate tool icon Tim
Thank you :) so was it never attatched to the command button? And I was just imaging it? I have tried to reset the shortcuts and to set a shortcut to the command key - but I would have sworn it was the same quick access as the spacebar is to the pan tool. thanks S_
