David Gross
#1 Posted : Wednesday, January 30, 2008 11:10:13 AM(UTC)
David Gross
Is anybody using the new Shark FX on a PC. I can not use this version, it has major problems for me like, I can not offset a face on a solid model without zooming so far out that I can't even see the face that I want to offset anymore. I need to be able to zoom in very close to pick vary small faces. And the space ball only works with wire frame. There are probably more problems, but I stop using it with the few problems that I have found.
David Gross
Dmg Design
Colgate, Wi.
#2 Posted : Friday, February 1, 2008 4:56:17 PM(UTC)
David,
We were not able to get this to repeat in 737. Can you download 738 and check again? We were aware of the spacemouse problems in earlier builds but believe these are now fixed.
