David Gross
#1 Posted : Friday, March 19, 2010 10:54:08 AM(UTC)
David Gross
I have a project I just started that has a model in it that seems to have problems (very slow to modify). So I converted it to surfaces and re stitch it into a solid. I wanted to see the difference in the sizes of the models, so I exported each one as a .sfx files. The stitch file was getting so big (1.25gig) I had to kill the process and it repeats, but if I removed the links it exported at a normal size. I can private email you if you would want to take a look at it.
David Gross
Dmg Design
Colgate, Wi.
